link agg. for switch redundancy
avinash.mangal
I have two switches cisco 4948 and wants redundancy using link agg.
like i will connect sw1 port 21 to sw2 port 22 and either sw1 goes down sw2 should take care or both should work as active-2 mode. can i do the same? if yes then how?
if no then give me suggestion to make redundancy between switches
Mark Yeates
Level 7
Level 7
You can use an etherchannel to achieve link aggregation and redundancy. Here is a guide to help you configure an etherchannel.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_13_ea1/configuration/guide/swethchl.html
Mark
