Link Aggregation and Multi-layer switches
MK31
Frequent Visitor
Frequent Visitor
1. Use Packet Tracer to put up the topology above. Connect the two multi–layer switches (MLS) with a Gigabit uplink
2. Configure IP addresses where appropriate. Include the layer–2 (access) switch and the workstation. Use a private IP address block.
3. Configure a two–port EtherChannel connection between the access switch and the MLS
2 Accepted Solutions
balaji.bandi
This is your home work, where do you stuck ?
BB
You can many ways,
Simple way, establish layer 2 from server to last switch (last switch have vlan interface , so they can ping or connect each other)
high level config :
Configure as below
interface GigabitEthernet1/0
switchport mode trunk
channel-group 1 mode active
interface GigabitEthernet1/1
interface Port-channel1
interface GigabitEthernet1/2
switch mode access
switch access vlan 1
Server configure IP 192.168.1.1 with the subnet 255.255.255.0
Configure as below
Last Switch (right side)
switch mode access
interface vlan 1
ip address 192.168.1.2 255.255.255.0
Then you should able to reach Server to 192.168.1.1 to 192.168.1.2
Note : make sure you no shutdown ports.
BB
balaji.bandi
BB
How can i make the server communicate with the Last Multilayer switch?
You can many ways,
high level config :
Configure as below
switch mode access
Configure as below
switch mode access
interface vlan 1
BB
