11-24-2021 08:25 PM
I am connecting vEdge 1k with 9500-32C-A through copper cable using GLC-TE. But the link is not coming up and getting below error.
*Nov 23 19:08:32.207 utc: %TRANSCEIVER-3-NOT_COMPATIBLE: R0/0: iomd: Detected for transceiver module in HundredGigE1/0/27, module disabled
Can you suggest pls
11-24-2021 08:28 PM
What firmware is the 9500 on?
11-24-2021 08:31 PM
It's 16.12.4
11-24-2021 08:49 PM
Disable auto-negotiation.
If problem persist, upgrade/downgrade to any IOS-XE version but do not use 16.12.X.
11-24-2021 11:56 PM
where is this error you getting ? Router or switch site ?
11-25-2021 09:17 PM
We are getting error n the switch. We are using IOS XE 16.12.04. auto negotiation is enabled as vEdge port is 1G.
