link teating method
pratik gandhi
Frequent Visitor
Frequent Visitor
Hi guys,
I want to test my internet link whic is of 4mbps. I want to understand how do we test this link on router, other than ping test wht could be done to check the thghput of. Link
5 Replies 5
Leo Laohoo
www.speedtest.net
InayathUlla Sharieff
Hi Pratik,
There are many third party tools to check the link, here are some below:
Here's free tool that I use from IXIA called Qcheck
http://www.ixiacom.com/products/display?skey=qcheck
IPerf: ( Install small iperf in a Station 1 and Station 2 and run it to get the graphical bandwidth value for that link.)
https://publishing.ucf.edu/sites/itr/cst/Pages/NSResources.aspx
http://en.wikipedia.org/wiki/Iperf
http://www.noc.ucf.edu/Tools/Iperf/
Inayath
********Plz rate all usefull posts.***************8
pratik gandhi
Frequent Visitor
Frequent Visitor
But wht if i wnt to test on router itself
I know thse apps which can test bt to test on router wht can we do
parvinder.s
Hi pratik,
router#sh int type module/slot command provides the 5 min avg. throughput.
thanks
