08-22-2016 04:18 AM - edited 03-08-2019 07:05 AM
I need to connect Intel X520-DA2 Dual Port 10Gb into Cisco Catalyst 3750-E. Can you help with cable, please? Need to be 10Gb
08-22-2016 05:19 AM
LC-LC is what you probably want going back to 3750 looking at x520 sheet , what's the distance between the 2 and what sfp are you using on cisco side
http://www.stordis.com/uploads/datasheets/Intel_X520_DA2_datasheet.pdf
Catalyst 3750-E Series |
Network Device |
Transceiver Model |
Minimum Software Release Required |
DOM Support |
Software Release |
WS-C3750E-24TD |
X2-10GB-LR |
12.2(46)SE |
12.2(35)SE2 |
X2-10GB-LRM |
12.2(46)SE |
12.2(40)SE |
X2-10GB-ZR |
12.2(50)SE |
12.2(50)SE |
DWDM X2 |
12.2(52)SE |
12.2(52)SE |
WS-C3750E-24TD |
SFP-10G-SR |
12.2(55)SE1 |
12.2(55)SE1 |
SFP-H10GB-CU1M |
12.2(55)SE1 |
WS-C3750X-24T |
SFP-H10GB-CU1M |
12.2(53)SE |
SFP-10G-SR |
12.2(53)SE |
12.2(53)SE |
SFP-10G-ER |
15.0(2)SE |
15.0(2)SE |
SFP-10G-ZR |
15.2(1)E |
15.2(1)E |
SFP-H10GB-CU1-5M |
15.2(2)E |
WS-C3750X-12S |
SFP-H10GB-CU1M |
12.2(55)SE5 |
SFP-10G-SR |
12.2(55)SE5 |
12.2(55)SE5 |
SFP-10G-ER |
15.0(2)SE |
15.0(2)SE |
SFP-10G-ZR |
15.2(1)E |
15.2(1)E |
SFP-H10GB-CU1-5M |
15.2(2)E |
