Linksys Cisco switch 24 ports
Dear All,
Just a question, I have doubt whether Linksys Cisco switch 24 ports SLM2024  and Cisco SLM2024 both are same. Both are look wise and colors are different??
If both are same , are they supports for VLAN?? Can use them in a VLAN environment?? Can anyone tell me the SFP for multimode and single mode which will work with SLM2024, and SLM2048 switches??
7 Replies 7
InayathUlla Sharieff
Answer; Both are same:
I would like to inform you that Cisco SLM2024 24-port Gigabit Smart Switch - SFPs  .. is EOS.
(http://www.cisco.com/c/en/us/products/switches/slm2024-24-port-gigabit-smart-switch-sfps/index.html)
2-2248 is also EOL/EOS:
http://www.cisco.com/c/en/us/products/switches/slm2048-48-port-gigabit-smart-switch-sfps/index.html
B)
Answer:
Yes they support VLAN, You can refer the below link for connfiguring the same:
https://supportforums.cisco.com/discussion/11579161/slm-2024-vlan-config-help
Inayath
*Plz dont forget to rate the usefull posts.
Dear,
Your answer are very very useful. Thanks a lot.
1. Can you suggest me the part of multi mode and single mode SFP that fit into SLM2024/2048 switches?
2. The SFP part no what you are going to suggest me , will it work with GLC-LH-SMD=     and GLC-SX-MMD=
Thanks in advance.
Below are the SFP's which are supported on these models:
MGBSX1
Gigabit SX Mini-GBIC SFP Transceiver
MGBLH1
MGBT1
1000 Base-T Mini-GBIC SFP Transceiver
MFEFX1
100 Base FX Mini GBIC SFP Transceiver Module
MFELX1
100 Base LX Mini GBIC SFP Transceiver Module
Ref:
http://www.cisco.com/web/IN/solutions/smb/hfn/assets/pdfs/cisco_apac_small_biz_guide.pdf
Inayath
********* Please rate all usefull posts*******
Dear ,
One side linksys SFP and the other side Cisco SFP (GLC-LH-SMD=     and GLC-SX-MMD=), are they compatible?
yes this is compatible.
example:
If you want to use GLC-LH-SM then I beleive you would need to use MGBLH1
Inayath
Please mark answered for helpful posts
Dear,
Thanks a lot.
you mean to say, both the side should match either single mode or multi mode.
yes.
Inayath
*Plz rate all usefull posts.
