Linksys E1200 Wireless-N Router
johnlloyd_13
Level 9
Level 9
hi all,
i'm planning to buy this wireless router but i don't see the specs whether it's backward compatible with 802.11b/g. can anyone confirm if it works with b/g. any personal review/experience with this device? thanks in advance.
http://homestore.cisco.com/en-us/Routers/Linksys-E1200-WirelessN-Router_stcVVproductId129966524VVcatId551966VVviewprod.htm
cindy toy
Level 7
Level 7
Hi John,
Thank you for your question.  However you posted your question in the Cisco Small Business Support community which is for Cisco Small Business products.  The E1200 is a Cisco Home product and the place to post your question is here: http://homecommunity.cisco.com/t5/Wireless-Routers/bd-p/Wireless_Routers
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Hi Cindy,
I've tried to go to the link you've provided but my Cisco login doesn't work. I assume I'd need to create a new one in order to join this forum. Anyways, I've got a feedback from a friend and went ahead buying this device.
Hi John,
Oops sorry I forgot to tell you about that. Yes, you are correct, your Cisco login will not work there.  They require a different login.
Cindy
