Password recovery for 6500 series Catalyst
Richard Ortiz
Hey All,
      I need to know why during the password recovery process for the CAT 6500 series with IOS that you have to do a "no shutdown" to the interfaces, again.
Router#copy startup-config running-config Destination filename [running-config]? <press enter>
!--- This pulls in the original configuration. Since you are already in privilege !--- mode, the passwords in this configuration do not affect you.
4864 bytes copied in 2.48 secs (2432 bytes/sec)
Router#configure terminal Enter configuration commands, one per line.
End with CNTL/Z.
Router(config)#enable secret < password > [Choose a strong password with at least one capital letter, one number, and one special character.]
!--- Overwrite the password that you do not know. This is your new enable password.
Router(config)#^Z
Router#
Router#show ip interface brief
Interface                  IP-Address      OK? Method Status                Prol
Vlan1                      172.17.10.10    YES TFTP   administratively down dow
Vlan10                     10.1.1.1        YES TFTP   administratively down dow
GigabitEthernet1/1         unassigned      YES unset  administratively down dow
GigabitEthernet1/2         unassigned      YES TFTP   administratively down dow
GigabitEthernet2/1         unassigned      YES TFTP   administratively down dow
GigabitEthernet2/2         unassigned      YES TFTP   administratively down dow
FastEthernet3/1            172.16.84.110   YES TFTP   administratively down dow
<snip>...
!--- Issue the no shut command on all interfaces that you want to bring up.
Edison Ortiz
During password recovery, you remove the previous configuration from the switch and goes back to factory default.
Default setting on interfaces is 'shutdown' which is a security measure.
When you perform the 'copy startup-config to running-config', you are transferring the config as is.
There isn't any command on the startup-config to issue a 'no shutdown'.
You can easily bring all switchports to no shutdown with the interface range command.
