02-11-2011 12:49 AM - edited 03-06-2019 03:29 PM
There is LMS 2.6 with RME 4.0.6.
We've devided to install CBS3000.RME40.v4-2.zip for the HP blade 3020.
According to the documentation this package has several dependancies.
I can not find the file SharedInventoryStack.RME40.v1-2-1.zip
And for the SharedSwimIOS.RME40.v1-11-7.zip package SharedSwimRtr800.vRME40.v1-6.zip should be installed first.
But in the doc for the SharedSwimRtr800.vRME40.v1-6.zip I see that it is dependent from SharedSwimIOS.RME40.v1-11-7.zip.
Which of these files should be installed first?
And where can i find SharedInventoryStack.RME40.v1-2-1.zip
Solved! Go to Solution.
02-11-2011 01:11 AM
This is not a right place to post it.
The right place for all issues related CiscoWorks is... https://supportforums.cisco.com/community/netpro/network-infrastructure/network-management?view=discussions
Please post your question there you will get quick look.
Hope that will help you.
Naidu.
02-11-2011 01:11 AM
Naidu.
02-11-2011 01:41 AM
thanks=)
