Load balancing in switch
tomy_bel303
Community Member
Hello
I have 2 servers ( solaris 10 )  as shown , i need to run load balancing between them to distribute the traffic  .
notice that the servers work together .
so how i can configure the switch to do this ?
what is the switch that i need ?
jonathanaxford
Level 8
Level 8
Hi there,
You can use Cisco IOS Server Load Balancing to achieve load balancing for the two servers, but I think it only runs on the Catalyst 6500 series switch.
Cheers
Jonathan
Mohamed Sobair
Level 11
Level 11
You need Layer-4 loadbalancer such as ACE, it can rapidly virtulize your Datacenter and provide you with application Acceleration and loadbalancing.
However, the Module is Only supported and can be used for 6500 Catalyst Switches.
Have a look at the bellow link:
http://www.cisco.com/en/US/products/ps6906/index.html
Mohamed
