Load Balancing
prakalaathan
I have 2  different ISP's 1)5 Mbps and 2)4Mbps .
Can i get sum of 9 Mbps speed , Is it possible ?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A sample document for doing what, EIGRP unequal costing or OER/PfR?
EIGRP variance:
http://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/13677-19.html
OER and NAT:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/99427-ios-nat-2isp.html
8 Replies 8
Joseph W. Doherty
Disclaimer
Posting
Yes and no.  There's lots of issues involved with trying to obtain the full sum.  (I.e. As in, can one flow use all 9 Mbps.)  However, if you want to take take advantage of the aggregate bandwidth, that's often not too difficult.  (I.e. As in, both links are used concurrently by multiple flows, but any one flow will not use more than 4 or 5 Mbps.)
Hi Doherty,
i have configured like this.
track 1 ip sla 1
 delay down 10 up 10
track 2 ip sla 2
 delay down 10 up 10
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description "RELIANCE"
 ip address 115.254.37.xx 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description "VODAFONE"
 ip address 123.63.247.xx 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 switchport access vlan 100
 no ip address
interface Vlan100
 ip address 192.168.2.1 255.255.255.0 secondary
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map isp1 interface GigabitEthernet0/1 overload
ip nat inside source route-map isp2 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 123.63.247.xx track 1
ip route 0.0.0.0 0.0.0.0 115.254.37.xx track 2
ip route 4.2.2.2 255.255.255.255 GigabitEthernet0/1 123.63.247.xx permanent
ip route 8.8.8.8 255.255.255.255 GigabitEthernet0/0 115.254.37.xx permanent
ip sla auto discovery
ip sla 1
 icmp-echo 4.2.2.2 source-interface GigabitEthernet0/1
 threshold 1000
 timeout 1000
 frequency 4
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0
 threshold 1000
 timeout 1000
 frequency 4
ip sla schedule 2 life forever start-time now
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
route-map isp2 permit 10
 match ip address 100
 match interface GigabitEthernet0/0
route-map isp1 permit 10
 match interface GigabitEthernet0/1
How it will work ?
Regards.,
Prakalathan.K
Disclaimer
Posting
I believe it will statically load balance, 50/50 outbound.
Hi Doherty,
Can i use Dynamic routing for this?
Regards.,
Prakalathan.K
Disclaimer
Posting
Only if your ISPs are willing.  Only EIGRP, as far as I know, will support unequal cost (static) load balancing.
OER/PfR, if your device supports it, can support unequal cost (dynamic) load balancing, using static routes.  You don't need cooperation from your ISPs for egress.
hi,
please share sample document related to do this.
Disclaimer
Posting
EIGRP variance:
OER and NAT:
Thanks Doherty.
