Load balancing
vinod.rathi
Is it possible to achieve load balancing on switch where we can group multiple IP address to be addressed with one virtual ip address and same will distribute to real IP's based on round robin fashion.
V
Edison Ortiz
You can achieve load balancing between multiple switches with GLBP.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiap_c/ch20/haipglbp.htm
HTH,
__
Edison.
