Load balancing****************************************
rbhan
Visitor
I have two 512 kbps of link from same ISP and both link were terminated on same router. I have different LAN/WAN pool for both ISP. M using nat on same router but want to do load sharing on both link.How it is possible.
Pls help me out,
Thanks ..
ohassairi
Level 9
Level 9
normally, we can use BGP for that 🙂 but if you can't do it because your ISP refuses to do it for you, think about PBR & Multiple Tracking.
this is an example of config: http://www.hassairi.50megs.com/#pbrtr
you should add the NAT commands...
HTH and hope it works 🙂
illusion_rox
Level 7
Level 7
Hi, you can do load sharing by dividing users in 2 groups and assign natting of group 1 to pool 1 and group 2 to pool 2 of the ISP, in this way i am quite sure that load sharing can be achieved,
RAKESH has posted the same question on the WAN Routing and Switching forum where it has generated several responses. I suggest that any further discussion of this question be consolidated in the WAN forum.
Rick
Rick
