load blance between 2 switches 6509 and 6513
mframadan
i have 2 switches 6509 and 6513
i connect with two link one is Fiber and other one is Wireless
how to make load balance using different media
Amit Singh
Various Options:
1. Static route load-balancing
2. Routing protocol load-balancing
3. Use Ether-channel and bundle the two links
HTH,
-amit singh
Istvan_Rabai
Level 7
Level 7
Hi Mohamed,
I definitely would suggest load balancing thith a dynamic routing protocol, namely EIGRP, as EIGRP is able to do load balancing between uneven metric routes.
With the fiber and wireless connections this is the case.
Cheers:
Istvan
