load-sharing per-packet with EIGRP
danny4569
Hi.
How can I load balance, per packet, between 2 fast-ethernet interfaces on a 2811 router running EIGRP, from the same IP source to the same IP destination?
Both links have the same metric and shown in the routing table.
Danny.
Giuseppe Larosa
Hello Danny,
EIGRP provides two equal cost paths to CEF.
To perform per packet load-sharing
int fx/y
ip load-sharing per-packet
int fx/z
do it on both routers
be aware that some types of traffic like VoIP can be severely affected by per packet load balancing
so per-packet can be an improvement or a worse problem
Hope to help
Giuseppe
Thanks Giuseppe.
I will try it.
Danny.
