Local SPAN and RSPAN to one destination port
owalter
The following scenario is given :
        P1-----------------                                     --------------------P1
         |  Switch 1    |------------------------------------|  Switch 2       |
         |                   |            Trunk                |                     |
        P2-----------------                                     ----------------------
Two Catalyst 3750 Switches connected with a trunk link.
On Switch 1 Port 2 (P2) a network analyzer is connected (single port)
Is there a way to SPAN traffic from port P1 on Switch 1 AND traffic
from port P1 on Switch 2 to this port (Port 2) ?
Any techniques to achieve this goal can be used (local SPAN, RSPAN...).
Aaron Harrison
From the manual:
The switch does not support a combination of local SPAN and RSPAN in a single session. That is, an RSPAN source session cannot have a local destination port, an RSPAN destination session cannot have a local source port, and an RSPAN destination session and an RSPAN source session that are using the same RSPAN VLAN cannot run on the same switch stack.
So- RSPAN the Switch 2 port accross the link to the  port X on switch 1.
SPAN the local Switch 1 port to porty Y on switch 1.
Don't allow ingress from the analyser, and attach both ports to it via a hub.
Or have two analysers.
Or - have a third switch as the destination RSPAN session for the ports from switch 1 and switch 2 (i.e. not mixing local SPAN and RSPAN).
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
From the manual:
Aaron
Hi Aaron,
thanks very much for your replay.
Excellent.
Oliver
