Showing results forĀ
Search instead forĀ
Did you mean:Ā
Lock IP Phone CISCO
youness hafid
Please  give me solution, I use Cisco Phones and i want to lock with code pin some phone
Thank you
devils_advocate
Level 7
Level 7
Can you explain what you mean in terms of 'locking' them?
Like a mobile phone you mean?
I am not aware of a pin code unlocking with Cisco phones but you could use Extension Mobility and ensure each user logs out every time.
Another option would be a forced authorisation code so each user would need to put in a code (i.e. pin) before they dialed a number.
yes like Mobile phone
