Logging in 4506 Switch
Sumit Basak
Hi All,
I am not getting interface up/down logs in my switch console through show logging command. Switch model cisco WS-C4506-E and IOS :- cat4500e-ipbasek9-mz.122-53.SG3.bin. I have done below mention configurations, please let me know if any thing missing, we can't configure logging level beyond informational.
Switch#sh run | in logging
logging buffered informational
no logging console
logging monitor informational
logging history informational
logging source-interface Vlan<l<an id>>
logging <<ip of syslog server>>
logging synchronous
Sh logging output :-
Console logging: disabled
    Monitor logging: level informational, 1 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level informational, 243 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 247 message lines logged
        Logging to <<ip of syslog server>>  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              247 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
cadet alain
How can you  get it on the console if you have it disabled:
no logging console
They should be in the buffer or on your syslog server
Alain
Leo Laohoo
By default on the 4500 and 6500, this option is disabled.   Enable by doing this:
conf t
interface
logging event link-status
end
thanks leolaohoo
If this answers your question, can I ask if you can mark this thread as "Answered"?
