Logging into A Cisco switch from another switch or router
Cisco10956
I have SSH enabled on switches and routers.
If I am already in a router how can I login to a switch from my router.?
Two ways I would like to know.
1. Login from a router to a switch.
2.Login from a switch to switch.
each have SSH
Please give an example.
Reza Sharifi
Use can use the same method for both the switch and the router:
ssh 10.10.10.1
10.10.10.1 is the IP address of the device you want to connect to.
If the destination device is not configured with the same user name as the source than you can add the use name to the string.  In this case the destination device is configured with username "test"
You also need to provide the password.
ssh -l test 10.10.10.1
Reza Sharifi
ssh 10.10.10.1
