logging on cisco 2951
donnie
Hi all,
I have a cisco 2951 with logging size set at 8192 bytes. Like to check the following queries.
1)What is the number of syslog messages that can be stored on my router with 8192 bytes
2)upon reboot of my router i notice the syslog messages would disappear. Is it possible to retain the syslog messages even when my router reboots?
There is no syslog server in my environment. TIA!
Reza Sharifi
Log size is usually small (about 1k) So, you could potentially store about 8000 lines.
No, it is not.  It is always best practice to use a syslog server, so you can go back and look at historic data in case of a reboot.
