09-12-2017 09:51 AM - edited 03-08-2019 12:00 PM
I have 6 sites with WS-C3560CG-8TC-S switches and one with the newer WS-C3560CX-8TC-S. We need to implement BFD on all of them to sort out our routing.
3560CG's are running ipbase 15.0(2)SE8
The 3560CX is running ipservices15.2(4)E2
I can issue all required BFD commands ok on the 3560CX but the 3560CG's won't accept any of them except for bfd all-interfaces under the ospf process section.
So, do I need to upgrade all the ipbase switches to ipservices, or do I just need to upgrade the IOS on the 3560CG switches to a newer version to support BFD? I have looked at the feature navigator but am none the wiser for it.
09-12-2017 10:15 AM
Can you not just use the BFD all interface then turn it off on the interfaces you dont want it to be on ?
There are two methods for enabling BFD support for OSPF:
dont think its softwrae as below
Prerequisites for BFD include:
09-12-2017 11:00 AM
09-14-2017 06:10 AM
09-14-2017 06:25 AM
09-14-2017 09:09 AM
09-14-2017 09:20 AM
.........I should've said, maybe I can fix it by adjusting the static default route AD on the L3 switch to be >110 and forget about BFD altogether??
