logging trap debugging and/or debug all
guillermo.ruiz
Level 2
Level 2
Currently my switch is properly configured for logging to a syslog server, and using ’logging trap informational‘‘
If I configure ‘’logging trap debugging’’...Do I create the same effect sending debug information to my syslog server as if I using ‘’debug all’’?
I really want to be sure about this before I flood my syslog server...:(
Please any comments are more than welcome.
guruiz
cadet alain
you will send debugging and lower level loggings to the server  so if you for example do a debug ip nat you'll send the  corresponding debug outputs but not more.but it may be a lot of output depending which debug command you entered.
Regards.
Alain
cadet alain
Regards.
Alain
Alain,
That's works for me !. Now, it has sense.
Thanks you
guruiz
