high CPU utilization issues
benedict dcunha
Community Member
Dear All,
I have a 2 cisco core (cisco WS-C6509-E (R7000) processor) and been working for quite sometime.
they are conneted with HSRP with active standby config with a 10 g module for redundancy
just today I see that the cpu utilization went to about 50% and its the same on both cores
its been always between 3 to 5 %
googling arround I found that netdr help in troubleshooting but could not really get something positive in tracing out the cause of the issue
below is the output of sh proc cpu of core B and also core A shows the same
Core-B#sh proc cpu SORted | exclude 0.00
CPU utilization for five seconds: 50%/36%; one minute: 48%; five minutes: 48%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  23    15187040 150730722        100  0.95%  0.29%  0.23%   0 IPC Seat Manager
462    18924316 122501511        154  0.55%  0.31%  0.29%   0 Port manager per
260    16893808  22686974        744  0.47%  0.46%  0.44%   0 CDP Protocol
266     8945852 204119832         43  0.47%  0.42%  0.44%   0 IP Input
459       31188 372100659          0  0.39%  0.37%  0.37%   0 HSRP Common
  11     8350916  37153191        224  0.39%  0.43%  0.41%   0 ARP Input
289        8604 764068581          0  0.15%  0.17%  0.15%   0 Ethernet Msec Ti
336     2035844  10887101        186  0.07%  0.08%  0.07%   0 CEF: IPv4 proces
217      244560   2458425         99  0.07%  0.02%  0.02%   0 Compute load avg
  51      148740   7014706         21  0.07%  0.07%  0.07%   0 Per-Second Jobs
517     3199180  82983066         38  0.07%  0.08%  0.07%   0 HSRP IPv4
CPU utilization for five seconds: 47%/34%; one minute: 48%; five minutes: 48%
  64    265906122207696984          0  9.43%  9.35%  9.35%   0 Net Input
260    16893816  22687109        744  0.55%  0.47%  0.44%   0 CDP Protocol
266     8945856 204120050         43  0.47%  0.43%  0.44%   0 IP Input
  11     8350928  37153215        224  0.39%  0.43%  0.41%   0 ARP Input
459       31188 372100767          0  0.39%  0.37%  0.37%   0 HSRP Common
289        8604 764068870          0  0.15%  0.16%  0.15%   0 Ethernet Msec Ti
517     3199180  82983095         38  0.15%  0.09%  0.08%   0 HSRP IPv4
357      767456   2985099        257  0.07%  0.04%  0.05%   0 HIDDEN VLAN Proc
  51      148740   7014718         21  0.07%  0.07%  0.07%   0 Per-Second Jobs
374       33980 186021477          0  0.07%  0.04%  0.05%   0 RADIUS
305     2250804   1193016       1886  0.07%  0.03%  0.02%   0 QOS Stats Gather
336     2035844  10887116        186  0.07%  0.08%  0.07%   0 CEF: IPv4 proces
CPU utilization for five seconds: 47%/34%; one minute: 47%; five minutes: 48%
  64    266072922209089683          0  9.27%  9.34%  9.35%   0 Net Input
   8    17847068   1118918      15950  0.87%  0.36%  0.29%   0 Check heaps
260    16894720  22697971        744  0.55%  0.44%  0.44%   0 CDP Protocol
  11     8351768  37155008        224  0.47%  0.40%  0.40%   0 ARP Input
459       31188 372109624          0  0.39%  0.37%  0.37%   0 HSRP Common
266     8946628 204131091         43  0.39%  0.39%  0.43%   0 IP Input
289        8604 764092148          0  0.23%  0.17%  0.16%   0 Ethernet Msec Ti
521     4964604  15243190        325  0.15%  0.05%  0.06%   0 SNMP ENGINE
336     2035900  10888915        186  0.15%  0.08%  0.08%   0 CEF: IPv4 proces
  51      148748   7015494         21  0.07%  0.07%  0.07%   0 Per-Second Jobs
517     3199224  82985086         38  0.07%  0.08%  0.07%   0 HSRP IPv4
357      767512   2985170        257  0.07%  0.04%  0.05%   0 HIDDEN VLAN Proc
305     2250868   1193044       1886  0.07%  0.02%  0.02%   0 QOS Stats Gather
the Net Input is very high
apprecite if someone can help and advice
thanks and regards
simon
5 Replies 5
Arumugam Muthaiah
Based on the output i can see that 34% caused by traffic being interrupt switched by the CPU. High CPU utilization on an interrupt level is primarily caused by packets handled on interrupt level.
Inorder to find the packet which is hitting the CPU, we can use the Netdr tool. This is available on the Catalyst 6500 with a Sup720 or Sup32 that allows one to capture packets on the RP or SP inband. The netdr command can be used to capture both Tx and Rx packets in the software switching path.
#debug netdr capture rx
#show netdr capture
Note: This debug command doesnt harm any production. Please take capture the data and share for the investigation.
Refer:
https://supportforums.cisco.com/docs/DOC-15608
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Dear Aru,
Really grateful and apprecite your immedite wise reply
by the way here below isa part of  the  sh netdr capure
------- dump of incoming inband packet -------
interface Vl12, routine mistral_process_rx_packet_inlin, timestamp 14:23:08.485
dbus info: src_vlan 0xC(12), src_indx 0x8A(138), len 0x5A(90)
  bpdu 0, index_dir 0, flood 1, dont_lrn 0, dest_indx 0x400C(16396)
  E8020400 000C0000 008A0000 5A000000 FE000510 00000008 00000008 400C8075
mistral hdr: req_token 0x0(0), src_index 0x8A(138), rx_offset 0x76(118)
  requeue 0, obl_pkt 0, vlan 0xC(12)
destmac 59.A3.BC.A1.4D.99, srcmac FE.80.00.00.00.00, protocol 0000
layer 3 data: 4034FCFF 7F204A42 880013C9 60000000 FE800000 00000000
              A04C59A3 BCA14D99 0201FFFF 1F500000 00FF0000 00000CFD
              00560000 BFEFFFFC 0000FFFF 0000008A 0000400C 1800
  F8020400 000C0000 008A0000 5A000000 FE000510 00000008 00000008 400CF075
  08020400 000C0000 008A0000 5A000000 FE000510 00000008 00000008 400CA07A
  30020400 000C0000 008A0000 5A000000 FE000510 00000008 00000008 400C087A
  48020400 000C0000 008A0000 5A000000 FE000510 00000008 00000008 400CE07F
  90020400 000C0000 008A0000 5A000000 FE000510 00000008 00000008 400C6870
is there so packets comming from vlan 12 if i am right
and the src mac is FE:80:00:00:00:00:00
and how does one disable the netdr capture
can I find the source ip from this
im sorry as am a novice in cisco
apprecite your kind help and advice
regards
simon
once again thanks in advance and god bless you
Dear Aru,
As per you advice and te link you mentioned I did manage to tract the inface on the core
its a gibex 1gb fibre port connected to a 48 port access switch
so i did shut the port and the utilization went to normal like a charm
but i am just stuck as to how i would find the user pc or pcs ( i mean the source IP responsible )
would really apprecite your kind help
Thanks and regards
simon
Hi Simon,
Sorry for the delay. Its good to hear that the problem has been fixed. I have analyzed the captured shared by you and see the detail below,
Interface traffic is coming from --> Vlan12
Ingress vlan for of the traffic --> 0xC(12) vlan 12
Destination index where the traffic is being sent --> 0x400C
You can track down the physical port where this traffic is sourced from by tracking down the mac-address FE.80.00.00.00.00
#show mac-address address FE.80.00.00.00.00 --> this will show the source interface. You can also look at ingress location of this traffic by taking the source index/ltl index
#remote command switch test mcast ltl index 8A --> which will show you source interface for reconfirmation
On our capture, i can see that flood bit is 1, If the packet that is captured has the flood bit set in the netdr capture, this traffic is being flooded to all ports within the vlan.
In order to see where this packet would be sent we need to add 8 to first value in the index (8 + 0x400C = C00C)
6500-2#remote command switch test mcast ltl index C00C --> will show you the interface
Please verify the access switch interfaces error counter / logs / traffic utilization and see if there is any misbehavior.
Aru
benedict dcunha
Community Member
Dear amu,
First of all you dont need to say sorry for the delay..
u r the one who was so helpful and really so grateful with your wise reply
and also there was no delay
actually after the link which you had mentioned trouble shootin was more ea=
sier
first i found the access switch which was connected and then show mac-addre=
ss address inter.... showed me the interface where the source pc was connec=
ted and goin on the core=20
show arp | include mac id resulted in showing the ip
maybe i feel that maybe not the perfect troubleshooting but you professiona=
ls have to excuse me.
by the way in future i guess I be able to handle such issues.
by the way anu a big favor if i can ask you .
from your expertise do you know of any professional paid software which wou=
ld be able to help us trouble shoot the source ip address .
in our network we dont have dhcp .. only static ips
once again thanks a million and god bless you
regards
simon
