logging
dinesh1977
Level 2
Level 2
Hi I have an issue with logging in one of my 6509 switch .Whe i checked the logs primary 6509 switch i can see lot of ospf route addition and deletion eg shown below :
":05:10.894: RT: add 172.17.92.0/24 via 172.16.255.17, ospf metric [110/121]" at
the same time when i check the secondary 6509 switches and my core 7609 routers i am not able to see the same logging messages . The logging configurtions of all my datacenter devices are same .
Could you pls help me to close this logging issue .
-- regards
kannan
Edison Ortiz
Type undebug all
It seems someone turned on OSPF debugging.
HTH,
__
Edison.
HI,
In addition to Edision's POST:
Type "term no mon"
So, the logging output are not thrown in the Terminal Screen instantly, which could disturb while doing some Important Configuration.
Pls Rate all Informative POST
Best Regards,
Guru Prasad R
kannan
What underlies the suggestion from Edison, and would make it effective, is that this output is produced by the fact that you are running debug ip rout on that switch but not on the other. So turning off debug will eliminate the output and make the output on all more similar.
Rick
Rick
