logical channel
dkblee
hi! is it possible to configure etherchannel for 2x10Gbps backbone link? or 2x 1Gpbs? Is that feasible or any example of such implementation?
mahmoodmkl
Level 7
Level 7
Well as long as both the sides are having equal speed,duplex,vlan information u can configure the ether-channel from fastethernet interfaces to gigabit interfaces.Well i didnt tried to configure it on 10gbps,but think it will not be a issue.
Mahmood
Agree with Mahmood, Channeling works over Fast Ethernet, Gigabit Ethernet, and 10 Gigabit Ethernet links.
HTH,
Mohammed Mahmoud.
