Looking for 3D model for IE-3200-8T2S-E
lentilbean
Beginner
Beginner
Hi. I've not been able to find CAD/model downloads on the Cisco site.  Can someone provide a 3D CAD file for the Rugged 3200 (IE-3200-8T2S-E) series switch?  Thanks.
Soichiro-Ono
Beginner
Beginner
Hello.
Unfortunately it is not published. Refer to dimensions and drawings.
Cisco Catalyst IE3x00 Rugged Series Switches Hardware Installation Guide - Cisco
Regard,
If you found this post helpful, please give it Helphul.
If my answer solved your problem, click "accept as solution" so that others can benefit from it.
有用な回答だと思われる際には いいね! をクリックして頂けると幸いです。
回答があなたの問題を解決した場合、解決済みをクリックしてください。
Recognize Your Peers
