Looking for a CISCO model
Hi all,
I'm looking for a model.
Looking to do NAT between two networks.
I must have a total of 6 gigabits interfaces.
I think I need a model 1900 series (router) with an extra card (4 ports at gigabit)
Can you advise me on a model?
A router is required to do NAT?
Thank you for helps
Ganesh Hariharan
Hi all,
Thank you for helps
Check out the below link on 1900 series routers with cisco ether switchh module
http://ciscosystems.com/en/US/docs/routers/access/1900/software/configuration/guideswitching_ps10538_TSD_Products_Configuration_Guide_Chapter.html#wp1076006
Hope to help !!
Ganesh.H
paolo bevilacqua
I think you are the end user ?
Please select first a reputable consultant, or certified Cisco partner to help you design and implement your network,.
Do not try to do it yourself, as that usually results in costly mistakes.
