04-05-2017 07:33 PM - edited 03-08-2019 10:05 AM
Running 3650 switch. I have this odd issue where I cannot get VLAN 26 pinging on it's /24, only gateway .1 and first public IP .2
This is what I see, which doesn't look normal. How do I fix this?
The server itself is configured fine (Centos 7)
[root@localhost ~]# cat /etc/sysconfig/network-s*/ifcfg-em1
TYPE="Ethernet"
BOOTPROTO="none"
DEFROUTE="yes"
IPV4_FAILURE_FATAL="no"
IPV6INIT="yes"
IPV6_AUTOCONF="yes"
IPV6_DEFROUTE="yes"
IPV6_FAILURE_FATAL="no"
IPV6_ADDR_GEN_MODE="stable-privacy"
NAME="em1"
UUID="******"
DEVICE="em1"
ONBOOT="yes"
IPADDR="xxx.xxx.30.2"
PREFIX="24"
GATEWAY="xxx.xxx.30.1"
DNS1="8.8.8.8"
DNS2="8.8.4.4"
IPV6_PEERDNS="yes"
IPV6_PEERROUTES="yes"
IPV6_PRIVACY="no"
Cisco3650#show ip route xxx.xxx.30.0
Routing entry for xxx.xxx.30.0/24, 2 known subnets
Attached (2 connections)
Variably subnetted with 2 masks
C xxx.xxx.30.0/24 is directly connected, Vlan26
L xxx.xxx.30.1/32 is directly connected, Vlan26
Show run looks normal?
Cisco3650#show run int vlan 26
Building configuration...
Current configuration : 85 bytes
interface Vlan26
description Server 26
ip address xxx.xxx.30.1 255.255.255.0
end
04-05-2017 08:00 PM
That output shows a normal behavior, the /24 represents the subnet mask related to the network and the /32 represents the IP associated to the SVI.
04-05-2017 08:05 PM
Doesn't sound right. I ran another check for another server (VLAN 12) on this same switch with a /22 subnet, not a /24.
Cisco3650#show run int vlan 12
interface Vlan12
description Server 12
ip address xxx.xxx.32.1 255.255.252.0
end
See, one line only.
Cisco3650#show ip route xxx.xxx.32.0
Routing entry for xxx.xxx.32.0/32, 1 known subnets
Attached (1 connections)
L xxx.xxx.32.1 is directly connected, Vlan12
04-05-2017 09:02 PM
It could be related to the network classes and their subnetted networks and masks, is that subnet a class C (192.168.x.x)?
For example:
Class B
172.17.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.17.0.0/22 is directly connected, Vlan30
L 172.17.0.1/32 is directly connected, Vlan30
This link explains the local entries:
http://www.ciscopress.com/articles/article.asp?p=2180208&seqNum=7
For example I configure the entire class B (summarized subnet) under the SVI
interface Vlan30
ip address 172.16.0.1 255.240.0.0
end
Switch#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
C 172.16.0.0/12 is directly connected, Vlan30
172.16.0.0/32 is subnetted, 1 subnets
L 172.16.0.1 is directly connected, Vlan30
But If I modified it to other CIDR lowest than 12, example 9
interface Vlan30
ip address 172.16.0.1 255.128.0.0
end
it will considered as /32 if it is a subnetted network and it is not using the proper subnet mask.
Switch#sh ip route 172.16.0.0
Routing entry for 172.16.0.0/32, 1 known subnets
The private classes are:
10.0.0.0/8
172.16.0.0/12
192.168.0.0/16
04-05-2017 09:02 PM
/24 = C class with a 255.255.255.0 subnet mask.
My settings are right, but IPs are not pinging. I think something is wrong with the VLAN26 itself. VLAN12 does not have the 2 (C and L) lines, just one and it has a /22 subnet.
Furthermore, I even tried modifying VLAN26 to have a /29 prefix primary and /24 subnet secondary. This always works on other servers I have with Centos, same switch too.
Even the /29 did not work except on gateway and primary .50 IP. .51 and rest did not ping either. Something is up with the actual VLAN I think.
04-12-2017 10:32 AM
Would appreciate help to get this strange issue resolved. I know for a fact I set up the IP assignment on the VLAN and the server's network config in Centos Linux itself. But, there's still a hiccup I believe on the VLAN side.
04-12-2017 11:16 AM
I'm going to backtrack a bit if you don't mind.
1. You have the following configured:
vlan 26
int vlan 26
ip address xxx.55.30.1 255.255.255.0
2. The server connecting to g0/21 (a vlan 26 access port) is configured to use an ip within the xxx.55.30.0/24 subnet. For example, xxx.55.30.2 255.255.255.0
Even with above setup, you cannot ping xxx.55.30.1, is this correct?
04-12-2017 12:43 PM
Wrong, as I stated a few times, I can ping .1 gateway and .2 public IP, but cannot ping the remainder on the /24 subnet.
04-12-2017 12:56 PM
And this remainder of the subnet is simply allocated to the server with the .2 IP address, is that correct ?
If so until you can describe how the server handles these IPs I'm not sure how we can help because it does not seem to be an issue with the switch ie. you can ping the SVI on the switch.
Jon
04-12-2017 01:15 PM
I see, I apologize for that. There's a lot of information to go through on this forum and I have some difficulties in fully understanding what all has happened.
I was wondering what you exactly mean by public IP. Where does this switch sit in your topology? E.g. LAN, DMZ, WAN? And what does IP xxx.55.30.2 belong to? Is this the server IP itself? Actually, what is the last octect of the server ip?
Generally when I see "public IP", I imagine a NATed IP address. In my opinion, you shouldn't be using a public IP block internally on your network.
Also, where does the remainder of the /24 subnet sit in your network? From your earlier results "show ip route xxx.xxx.30.0", I noticed you had 0 routes for other devices. If they were on the same switch, they should be able hit since you can reach default gateway. However, if they aren't on the same switch, you will need to:
1. Verify you're trunking configurations
2. Verify the other switches have vlan26 configured
3. Verify that access ports are configured for vlan26 on the other switches
4. Verify your routing via static routes or a dynamic protocol
Hope some of this helps and I apologize again if I'm repeating things that have already been checked.
04-12-2017 11:14 AM
Hello
So just confirm - you did or didn't try a different host other than this server and connect it to the switches and test?
As stated if the switch was the problem then I'd expect ever other server have the same problem
The switch config looks okay-cannot comment on your server hence why a suggested device change maybe with a laptop or pc twith correct assigned IP address -subnet- default gateway and post the test results
res
Paul
04-07-2017 01:07 PM
Once again:
Cisco3650#show run int Gi1/0/21
Current configuration : 282 bytes
interface GigabitEthernet1/0/21
switchport access vlan 26
switchport trunk allowed vlan 3,5,8,17-19,26,39,43,50,51,70,74,76,78,84,97-99
switchport trunk allowed vlan add 101-103,108,110,112,119,500,600,611,612,950
switchport mode access
speed 100
end
interface Vlan26
end
Gi1/0/21 Server 26 connected 26 a-full 100 10/100/1000BaseTX
04-10-2017 03:00 AM
Hello
Can you try attaching host pc instead of your server to an access port on either switch for any of the 4 vlans your having issues with, Assign this host addressing and see if you can reach the other vlans
This will tell either way if its the switch or the server causing this
res
Paul
04-06-2017 01:17 AM
Hello
Do you mean by this you cannot ping other vlans?
Can you ping between vlans?
Do you have ip routing enabled?
Do you have the SVI ip address for 26 configured anywhere else?
Have you created the L2 vlan for this vlan?
What does the arp table show for your server
Have you tested another device other than your server on this vlan?
res
Paul
04-06-2017 06:39 AM
This issue is solely VLAN26. All other VLANs work fine and ping fine. Why would I need to create an L2 VLAN for the VLAN? I'm not understanding. My simple standard step is "vlan #", assign IPs and port and that's it. It works just like the 20+ others working now.
How/where do I check that?
Not sure what you mean, all other VLANs work fine on the switch so the answer is yes.
