Loopback Interface down on SUP Switchover in VSS Cluster
j.hoffmann
I've realized that a configured loopback interface on a VSS Cluster (2x Cat6509 with VS-S720-10G) is going down for a short time on SUP Switchover
caused by
(a) pulling the active SUP
or
(b) CLI command : "redundancy force-switchover"
The loopback interface lo1 is configured as source of syslog messages ("logging source-interface Loopback1").
Because of the interface down a lot of syslog messages are sent with an other source IP as configured on the loopback interface.
Is there a possibility to avoid the down of the loopback interface on SUP switchover?
Thanks for any advice!
Jens
andrew.prince
Level 10
Level 10
Your devices could be in RPR mode post the output of " show redundancy"
The cluster is configured with SSO..
VSS-Cluster#sh redundancy
Redundant System Information :
       Available system uptime = 8 weeks, 1 day, 11 hours, 27 minutes
Switchovers system experienced = 17
              Standby failures = 0
        Last switchover reason = active unit removed
                 Hardware Mode = Duplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 2/5
        Current Software state = ACTIVE
       Uptime in current state = 1 day, 1 hour, 50 minutes
                 Image Version = Cisco IOS Software,
                          BOOT = sup-bootdisk:,1;
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 1/5
        Current Software state = STANDBY HOT
       Uptime in current state = 1 day, 1 hour, 43 minutes
The loopback interface is down for about 10 seconds in case of SUP switchover.
Is this a normal behavior or a bug?
