lot of output drops
Adi Arslanagic
I have a problem with a lot of output drops on one of the fastethernet interfaces (router is Cisco 3745)
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 000d.bc09.cba1 (bia 000d.bc09.cba1)
Description: TRUNK
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 9/255, rxload 9/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d08h
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 2938909
Queueing strategy: fifo
Output queue: 0/4096 (size/max)
5 minute input rate 3848000 bits/sec, 1179 packets/sec
5 minute output rate 3754000 bits/sec, 923 packets/sec
132391896 packets input, 3083523931 bytes
Received 8144821 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
114686595 packets output, 431450282 bytes, 0 underruns
0 lost carrier, 0 no carrier
There are about 50 subinterfaces on this physical Fa0/1
there is an average of 40 drops per second even though output queue is empty
while googling I found a topic with similar situation - http://atm.tut.fi/list-archive/cisco-nsp/msg16023.html
Any ideas?
14 Replies 14
Edison Ortiz
Ok, let's start fresh ---
clear the counter and change the load-interval to 30 seconds. That value will give us a better indication of the current flow, a 5 minute average does not represent burst traffic that well.
What device is connected at the other end ?
Are you forcing the speed/duplex on each end or going auto/auto ?
__
Edison.
Ok, here it is
Last clearing of "show interface" counters 00:00:15
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 608
30 second input rate 4017000 bits/sec, 1170 packets/sec
30 second output rate 3946000 bits/sec, 906 packets/sec
19335 packets input, 8250918 bytes
Received 1358 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
14526 packets output, 8096392 bytes, 0 underruns
608 drops in 15 sec
Device on the other end is Catalyst 2948G, and yes speed and duplex are forced to 100/full
Both input and output queues sized to 4096? Could you post stats from show buffers?
4Mbps shouldn't produce output drops.
Have you tried replacing the cable ?
Can we change from 100/Full Duplex to Auto/Auto at both ends ?
When this problem started ?
Can you post the show proc cpu from the router?
__
Edison.
What are you using as the native VLAN on the trunk port on the switch and the router?
First of CPU is very low:
CPU utilization for five seconds: 5%/4%; one minute: 5%; five minutes: 6%
I have been tweaking buffers a bit (small and medium):
Buffer elements:
1115 in free list (500 max allowed)
1785674357 hits, 0 misses, 1119 created
Public buffer pools:
Small buffers, 104 bytes (total 134, permanent 125, peak 502 @ 7w0d):
105 in free list (50 min, 175 max allowed)
3448041090 hits, 603297 misses, 186585 trims, 186594 created
150475 failures (0 no memory)
Middle buffers, 600 bytes (total 75, permanent 75, peak 623 @ 7w0d):
61 in free list (35 min, 135 max allowed)
925561213 hits, 589636 misses, 46420 trims, 46420 created
202647 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 74 @ 7w0d):
50 in free list (5 min, 150 max allowed)
316676719 hits, 36790 misses, 832 trims, 832 created
35842 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 13 @ 7w0d):
9 in free list (0 min, 100 max allowed)
835 hits, 35009 misses, 39 trims, 39 created
35009 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 4 @ 7w0d):
1 in free list (0 min, 10 max allowed)
50 hits, 34959 misses, 5027 trims, 5028 created
34959 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 11 @ 7w0d):
1 in free list (0 min, 4 max allowed)
5767 hits, 34973 misses, 6831 trims, 6832 created
34921 failures (0 no memory)
Native VLAN is VLAN1 on the switch, but I don't have a subinterface with vlan1 configured on the router
The strange thing to is that FastEthernet0/0 interface that serves as an uplink for the subinterfaces configured on fa0/1 does not have any drops:
Last clearing of "show interface" counters 1d09h
Input queue: 1/1024/0/0 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/1024 (size/max)
5 minute input rate 3873000 bits/sec, 894 packets/sec
5 minute output rate 3843000 bits/sec, 1055 packets/sec
120868899 packets input, 1879487910 bytes
Received 45350 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
127840254 packets output, 2826664173 bytes, 0 underruns
same story here - speed/duplex fixed, same endpoint (C2948G)
Also there is a second router (7204VXR) with identical config, and identical problem, so I don't think it is a cable fault.
Thanks for the interest in my problem :)
Why are the packets sitting in the Input queue on the switch interface. What does the CPU utilization look like on the switch?
This is show interfaces output of the router FastEthernet 0/0 interface, the switch is running CatOS.
The CPU on switch:
CPU utilization for five seconds: 53.75%
one minute: 45.70%
five minutes: 43.19%
It is always ~50% even at very low traffic.
Also there are none drops on switch interfaces.
Lots of buffer failures!
From http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a7b80.shtml
If there are no buffers available, and fast switching is enabled, there is a buffer failure and the packet is dropped. When the buffer pool manager process detects a buffer failure, it "creates" a new buffer to avoid future failures.
Possible cause of the counted output drops?
I guess it could be, thats why I've been tweaking the buffers. But the strange thing to me is that Fa0/0 interface that 'mirrors' packets from Fa0/1 is not dropping any packets!?
"But the strange thing to me is that Fa0/0 interface that 'mirrors' packets from Fa0/1 is not dropping any packets!?"
Perhaps because the mirroring, although in/out bits rates are close, a little more separation between in/out packet rates?
The large queue settings of 4,096, both in and out, are these defaults, or have they been set manually? If not defaults, try defaults. If defaults, try 75 in and 40 out.
PS:
If your trying to avoid any drops with large queues, it can be counter productive. With TCP, often drops are the only active flow control mechanism to deal with oversubscription.
I have increased queue depths yesterday to see if it had any effect, but as it seems it doesn't since packets are being dropped without the queue filling up.
Then we might still be dealing with a buffer tuning issue.
I would suggest returning in/out queue sizes back to their defaults (and confirmation of what those defaults might be).
You might also try automatic buffer tuning as suggested in:http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbfcc48/0#selected_message
Returned the queue depth to default level, and turned on automatic buffer tunning. I'll report if there are changes.
