lots output buffer failures on one side ???
rico_hao40
I have 3550 through fibre converter goes to 2950, on 3550 side I have lots of underruns and output buffer failures, but on 2950 side no such failures.
3550:
FastEthernet0/42 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 000b.5f32.d22a (bia 000b.5f32.d22a)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:55, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 5000 bits/sec, 7 packets/sec
15213424 packets input, 99938169 bytes, 0 no buffer
Received 8700189 broadcasts (0 multicast)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 8658647 multicast, 0 pause input
50054756 packets output, 4257661420 bytes, 4894 underruns
0 output errors, 0 collisions, 1 interface resets
4894 output buffer failures, 0 output buffers swapped out
2950:
FastEthernet0/24 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0013.c304.1558 (bia 0013.c304.1558)
Description: backbone to 3550
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input 00:00:01, output 00:00:02, output hang never
5 minute input rate 18000 bits/sec, 22 packets/sec
5 minute output rate 11000 bits/sec, 14 packets/sec
41708620 packets input, 2497436974 bytes, 0 no buffer
Received 35994473 broadcasts (0 multicast)
0 watchdog, 20939622 multicast, 0 pause input
13490662 packets output, 2760151410 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Is the media converter ??
smothuku
Level 7
Level 7
Hi ,
Here is an explanation of underruns & output buffer failures:
Output buffer failures description: Cisco IOS sh interfaces counter. The number of failed buffers and the number of buffers swapped out.
Common Causes: As an example, consider a scenario where a 1gig multicast stream is being forwarded to 24 100 Mbps ports. If an egress interface is over-subscribed, it would be normal to see output buffer
failures incrementing along with Out-Discards.
Underruns Description: The number of times that the transmitter has been running faster than the switch can handle.
Common Causes: This can occur in a high throughput situation where an interface is being hit with a high volume of bursty traffic from many other interfaces all at once. Interface resets may be occurring along
with the underruns.
It basically means due to overwhelming amount of traffic sent to the switch port, it will use Tx buffer and when this buffer is full, we start to see dropping of the packets and counters for the underruns and output buffer failures will be increased.
**** It is normal to see a large number of frames being discarded when an egress
interface is over-subscribed .The "Discarded frames" count indicates how many packets are dropped because the egress notify queue is full due to over-subscription. This is also reflected in the "Output buffer failures"
statistics in "show interface", which has nothing to do with the CPU buffers in "show buffers".
You can check the bug CSCdy09531 :Output buffer failures on fastethernet ports.
Hope it helps you.
satish
