01-27-2013 07:27 AM - edited 03-07-2019 11:20 AM
4506 switch had experienced low on memory message while taking console. and got below console message
%SYS-2-MALLOCFAIL: Memory allocation of 784 bytes failed from 0x1025F354, alignment 8
Pool: Processor Free: 123028 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
It's running in cat4000-i9k91s-mz.122-25.EWA7.bin
tech support has attached. Plz provide the resolution.
Solved! Go to Solution.
01-27-2013 05:38 PM
The only way to fix that is to reload the switch . It has a slow memory leak and reloading will fix that at least temporarily. I would upgrade it also if possible.
01-27-2013 01:50 PM
Wow, that's a pretty old IOS. Did you ever consider upgrading to something newer?
01-27-2013 11:30 PM
Planning to upgrade 122-54.SG1 enterprise services version. Will it help any way?
01-27-2013 11:45 PM
Go through the Release Notes and you'll be able to determine if this IOS is suitable.
01-28-2013 11:45 PM
Thxz, I"ll do it
01-27-2013 05:38 PM
01-27-2013 11:29 PM
Hi glen,
Thanks for your support. Is there any permenant solution to fix this issue?
01-28-2013 05:01 AM
I haven't found that to be a common problem so once you upgrade unless you have a hardware issue I doubt you will see it again.
