%% Low on memory; try again later
Dear Folkz,
I've 1905 router running with c1900-universalk9-mz.SPA.151-2.T2.bin.
I'm getting "%% Low on memory; try again later" whenever taking console.
We've the below logs from the router.
%SYS-2-MALLOCFAIL: Memory allocation of 21840 bytes failed from 0x24890DB0, alignment 0
Pool: Processor  Free: 175960  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Licensing Auto Update Process", ipl= 0, pid= 12 -Traceback= 0x23414708z 0x24A13350z 0x24885A78z 0x248BD2FCz 0x2487FEB4z 0x2487DD1Cz 0x2487E648z 0x2487D614z 0x2102AC40z 0x233E7980z 0x233E7964z
*Aug  6 05:06:55.442: %LICENSE-2-VLS_ERROR: 'VLSnotifyBirthAndExpiryEvents' failed with an error - rc = 25 - 'Error[25]: Could not understand the message received from license server on host "no-net".
Client-server version mismatch?
' -Traceback= 0x233E7980z 0x233E7964z
*Aug  6 05:07:55.446: %SYS-2-MALLOCFAIL: Memory allocation of 21840 bytes failed from 0x24890DB0, alignment 0
*Aug  6 05:07:55.450: %LICENSE-2-VLS_ERROR: 'VLSnotifyBirthAndExpiryEvents' failed with an error - rc = 25 - 'Error[25]: Could not understand the message received from license server on host "no-net".
Kindly help me :-(
muca
Level 3
Level 3
Hi Muru,
I would check the memory/cpu utilization and see if there anything that is eating the memory that you could free.
It looks like a bug and you may need to reboot your router.
Check this post. It might help you.
https://supportforums.cisco.com/thread/344423
glen.grant
  Unless it free's up in a day or so the only fix for this is going to be to reload the box. It apparently has some sort of memory leak . Check for issues with your code release in bugtool.
Leo Laohoo
It's a known memory leak bug.  You'll need to upgrade your IOS.
