Low privilege account creation
vipinrajrc
Level 3
Level 3
Hi Experts,
I need to create a low privilege account, just to view only show commands. I already have created a full privilege account (local username) and binded with the telnet line. also enable password is there.
I tried by creating a enable password with level1  priviliege.
please provide a suitable suggestion.
Vipin
Thanks and Regards, Vipin
Hi Vipin,
See the below example configs.
#username six privilege 6 password 0 six
privilege exec level 6 show running
As per above config user six is able to Telnet in and execute the show run command, but the resulting configuration is virtually blank because this user cannot configure anything (configure terminal is at level 8, not at level 6). The user is not permitted to see usernames and passwords of the other users, or to see Simple Network Management Protocol (SNMP) information.
Please rate the helpful posts.
Naidu.
I just need to create privilege level with the following commands
show running-config
sh ip int brief
sh cdp neighbors
ping
traceroute
sh interface
sh ip route
I tried with the level6, but from show run there is nothing .
Is there any special meaning to the levels? Why you specify level 6?? Why not level 5 or level 7?????
That is my doubt... is there any special meaning for different levels????
Vipin
Dear Vipin,
Creating "views" is a good option..
http://www.fir3net.com/Router/Cisco-Router/creating-cli-views-on-a-cisco-router.html
Thank you
Naren
