Testing LAN QoS
nikalleyne
Level 3
Level 3
Guys,
How do I go about testing my LAN QoS if there is no congestion?
created an access-list
ip access-list standard TEST
permit host 192.168.0.1
defined a class map
class-map match-any TEST
          match access-group name TEST
defined a policy map
policy-map TEST
     class TEST
          set dscp af41
Assigned the config to my interface
int fa0/34
service policy ingres TEST
On my trunk interfaces i have
mls qos trust dscp
However, when I loaded up wireshark and checked a server on the LAN but the DSCP value are all 0s
Any suggestions.
Edison Ortiz
The markings will be applied regardless of congestion.
Did you enable mls qos globally?
What type of hardware are you using?
Based on your config, you can test by simply pinging from a workstation running wireshark to 192.168.0.1 (which I'm assuming it is the server). The ICMP packets should have AF41.
Edison
Edison Ortiz
Edison
Edison,
Thanks for the response. You were correct I did have everything in place. My problem, I was looking at the server for the marking and not the client.
Yep I did enable mls qos globally
platform is 3560
Thanks for the headsup
