Low Transfer Rate On 2960-S Switch
I have 2 PCs (1gbps lan card each ) connected to Cisco 2960-S switch.
The bandwidth of all ports on 2960-S is set to 1gbps manually.
However whenever I transfer any file between the two I don't get transfer rate more than 12MBps/96mbps.
Theoretically it should be 125MBps but why am I getting such low transfer rate?
Regards.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Bandwidth is set manually, eh?  Have you checked for a duplex mixmatch?
Under every interface on switch we have set full duplex and 1gbps bandwith manually.
Ex,  int gi1/0/1
        duplex full
        bandwidth 1000000 (in kbps)
