Bookmark
Subscribe
3611
Luis Apodaca
luis.apodaca
hi guys i am a rookie in CCNA and still learning
i just have one question before do a maze with my Switch Catalyst 3750, can i do more than one ip route for a same vlan, and i meant the whole network, something like this;
# ip route 0.0.0.0 0.0.0.0 192.168.18.250 /// Main Server
# ip route 0.0.0.0 0.0.0.0 192.168.18.18 //// backup server
i need to set up a gateway like a backup service, in case the main server goes down, both of them are Virtual machines but in diferents physical server, the entire network point to the main server (sophos UTM 9) this one is my gateway, and firewall
the second one (ClearOS 7) is just for have internet service, no more than that, i dont care if we dont have firewall and all those service, is only for have time for work with the main one and do some support, about 30 min and we will be fine
all is fine but the physical servers are to old and we had crashes before, so we need to have an another for the users can keep working during the crashes
thanks in advance and best regards.
Hi Luis,
It was a pleasure
Have a great day
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
26 Replies 26
Julio E. Moisa
Hi Luis,
Yes you can configure 2 or more static route for backup, it is also called floating route, for example:
ip route 0.0.0.0 0.0.0.0 192.168.18.250 name Primary
ip route 0.0.0.0 0.0.0.0 192.168.18.18  20  name Secondary
You can configure highest administrative distance for backup, the default administrative for a static route is 1, so you can configure 2+ for other static routes.
http://techintuition.com/cisco/floating-static-route
Hope it is useful
tank´s for your response
but what about that number "20" you wrote before the name, what is it means?  or  what it is for ?
regards.
Hi Luis,
It is any number, the administrative distance for static routes is 1. I wrote 20 but it could be any number into the range 1 - 255. The lowest value will be always preferred.
Sintaxis:
ip route <destination network> <subnet mask> <next hop IP> < (1 - 255) administrative distance>
If you have 2 static routes for identical destination, example:
ip route 0.0.0.0 0.0.0.0 192.168.18.18 name Secondary
You can add a higher value than 1 for the back up route, so if the primary route is down the traffic will be moved through the backup.
ip route 0.0.0.0 0.0.0.0 192.168.18.18  5 name Secondary
ok totaly get it now
when i received your email, i was reading the info in the link you sent.
thank and regards
Hi Luis,
It was a pleasure
Have a great day
sorry for so late response, but i I could not try until yesterday
Its not working, i set up the floating route as you told me, and for do a test, i just turned off mi main firewall and i lost internet, then i try to set up the second ip route, (i mean the floating route) like a secondary DNS in mi pc and still i have not internet.
should i do something more ??? some test before turn off the main firewall ?
thanks and regards.
Hi Luis,
Will be a pleasure to assist you, do have a diagram to share? may be we could implement HSRP.
have no diagram but let me explain you mi Lan
The switch (catalyst 3750) is the DHCP, VTP and spanning tree server for all the lan an also its doing the static route´s (we have 9 more catalyst switch´s in the campus)
We have 23 vlan for production, and 2 aditional for ISP, one for each ISP we have, also we have in work 5 Access-List, in those all the vlans have acces to the IP for the Main Server UTM Sophos 9.4 (Gateway-Internet DNS-Firewall, is a PC), and also all the vlans have acces to the IP for the second server (VM in a server, ClearOS 7, not a PC), the last one is the one we want to use only like a gateway in transparent mode NO Firewall, the one for the floating route
The second ISP is only for backup the internet service and is only for 3 vlan´s, only the most important of them , that job is done by the UTM Sophos 9.4, in al  l the Pc in the campus the DNS are pointing to the main server, and we are testing the floating route by setting the second server like a secondary DNS for PC, and turnin off the main one, and that is the test wich doesnt work
for both server we have good ping result from any Vlan.
i guess that is all, please for any question, doit at any time
PD: by the way, what about use both server at the same time for all the lan, not like a floating route, is that posible ?, that is a project for the future, so Would you mind point me to the manual o correct reference please.
Thank you Luis,
If you like we can talk spanish, at the meantime I understand the Main Server UTM Sophos 9.4 has NAT role in order to get Internet access through the primary ISP.
Is similar situation with the back up ISP, what device is making NAT?
About the last question, usually we have a primary link and a backup but you could redistribute the traffic via different ISP's using a firewall or using BGP.
Los 2 ISP son administrados por el UTM y el nateo se realiza en su mayoria por la interfaz del ISP Principal, solo el acceso a nuestra plataforma Escolar tiene Nateo atravez de los 2 ISP al mismo tiempo, la interfaz del ISP secundario esta en modo Standby, en espera de que la primera Falle
en el segundo servidor no tengo ningun tipo de nateo, aun no llego a esa parte, lo primero que necesito hacer es que se pueda usar como gateway par adistribuir internet en caso de que el UTM Sophos falle
Buenos dias Luis,
Una consulta, como tiene configuradas 2 rutas por defecto (0.0.0.0 0.0.0.0 <siguiente salto>)apuntando a diferentes siguientes saltos, para el backup el dispositivo o servidor deberia de tener un NAT para salir a Internet y saber como regresar los paquetes a las redes internas, seria el mismo proceso que hace el dispositivo del camino primario.
La ruta estatica flotante funciona de esta manera:
La primaria si detecta que el siguiente salto esta caido, ya no sera funcional esta ruta estatica y entrara en funcionamiento la de backup siempre y cuando el siguiente salto configurado este activo.
Si usted apaga el dispositivo primario y ejecuta un tracert desde una computadora, el camino deberia de ser por el camino de backup, siempre y cuando el dispositivo del backup este encendido.
Los unicos dispositivos que pueden hacer NAT son Routers, Firewalls y talvez en algunos caso servidores.
any comment ?
in english this time;
The 2 ISPs are managed by the UTM and the nat is done mostly by the interface of the Primary ISP, only access to our School platform has Nat through the 2 ISPs at the same time, the secondary ISP interface is in Standby mode , Waiting for the first  one fail in some how
On the second server I do not have any type of nat, I still do not get to that part, the first thing I need to do is that server can be used as a gateway to serve internet in case the UTM Sophos fails
any coment ?, i let you my "sh run" result if is helpfull for you,, please be my guest
alguna respuesta ?, te dejo el sh run por si te es util
thanks in advance, i will be waiting
gracias...
Buenas noches Luis,
Muchas gracias, voy a revisar el documento.
saludos
