mac address for each access port in catalyst switch
13jobsp90
Is there any command to get mac address for all access ports in a particular  Cisco Catalyst 2960 switch. sh mac address table command shows the learned mac id of all ports of the neighboring  switch also. How do i get the mac address for only the connected access ports of that particular switch only not the neighboring  switch?
8 Replies 8
Leo Laohoo
sh mac address | include F
13jobsp90
Not working in Cisco 2960 model catalyst switch.What is the exact command?
show ip arp
What, exactly, is the model of the 2960 switches?
Try this:
sh mac address-table | exclude G|CPU|Vl
what is G, cpu, V1?
Joseph W. Doherty
An L2 port does not have a MAC.
Rereading your OP, I believe I misunderstood your question.  I thought you were asking for the MACs of the access ports, themselves.
Are you trying to just obtain the MACs of hosts only directly connected to access ports of a switch?  If so, there's no single command that will provide just those MACs.  If fact, L2 being what L2 is, even using multiple commands, I don't believe there's a guaranteed method to determine such hosts.  That's not to say, using multiple commands, you might be able to make some probability of whether a MAC might be a directly connected host, but again, if many cases, don't believe it can be guaranteed.
If the switch and host support CDP and/or LLDP, "seeing" a CDP/LLDP relationship, would probably be the best indicator, but even that could be incorrect.
if I give sh mac address table interface, it will show the mac address of that particular port.
