Cisco CBS 350 model switch showing continous log message
13jobsp90
04-Oct-2024 04:44:28 %2SWMACTBL-N-PORTMACHASHFAILED: Port gi1/0/48 ,MAC __________ : Cannot be added to the FDB (Hash Table Collision).
The above message pops up every time continuously. What is this & Why it is happening?
6 Replies 6
Mark Elsen
          - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwm27756
   M.
is it a bug?Any workaround for this ?
   - It is a bug ''because of the bug report' ; but there are no workarounds mentioned , neither any fixed versions , then you need to contact Cisco supporthttps://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
   M.
balaji.bandi
are you running the firmware version mentioned in the bug ? try reload and switch and observe.
is this effecting the Live traffic, then reason the SMB tac for the fix.
BB
13jobsp90
3.2.0.89 version
how many VLAN you have in that switch, and where is the MAC address do you any where in the network as duplicate ?
post the output of this - gi1/0/48
If this is only log you can ignore it, if this performance issue then you need to look deeper, as i mentioned is this only one switch in the network or connected to other part of the network ?
BB
