MAC FLAP NOTIFICATION BEGINS AFTER CONFIGURING RSPAN
legacynetwork
I have core switches in stack and those are connected to access stack using port channel. Configuration is as below. I have created VLAN 250 for RSPAN Purpose and configured same on both. Moment I enable monitoring session, I start receiving logs "SW_MATM-4-MACFLAP_NOTIF" and says hosts in VLAN 250 are flapping Between PO2 and PO3. I see lot of random mac address, there is no pattern, no repeated mac address,  these logs only starts when monitoring session is enabled and not sure why it keeps referring to VLAN 250 which is solely created for RSPAN purpose. Please advise what might be going wrong here.
On Core Switch Pointing to Access Switch 101
interface Port-channel2
switchport mode trunk
storm-control action trap
interface TenGigabitEthernet1/0/5
channel-group 2 mode on
spanning-tree portfast disable
spanning-tree bpduguard disable
interface TenGigabitEthernet2/0/5
From Access Switch101 Pointing back to Core switch
interface TenGigabitEthernet1/0/2
channel-group 1 mode on
interface TenGigabitEthernet3/0/2
interface Port-channel1
Giuseppe Larosa
Hello @legacynetwork ,
have you added the rspan command under vlan 250 on both core switches ?
one of the purposes of this command is to disable MAC address learning on VLAN 250.
Hope to help
Giuseppe
Both core switches are in stack so I see single configuration and yes, RSPAN is configured under vlan 250
