PoE on C1121-8PLTEP
peter.shafer
We have started using C1121-8PLTEP in our branches.
Today needed to use the PoE for the first time. Cannot get power on any of the 8 ports.
This looks ominous:
sh power
Main PSU :
Configured Mode : N/A
Current runtime state same : N/A
PowerSupplySource : External PS
POE Module :
Total power available : 0 Watts
sh ver
Cisco IOS XE Software, Version 17.03.03
Cisco IOS Software [Amsterdam], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.3, RELEASE SOFTWARE (fc7)
I suspect there is something required to enable it. But cannot find where/how.
Any assistance would be greatly appreciated
Thanks in advance
Peter
So, it seems it is an option. Great Data Sheet Cisco. In the "Product Specifications" table, no mention of the optional module.
And we missed it at the top of the doc: Platform architecture and capabilities.
Going to be an interesting conversation.
Thank You Leo for pointing out our stupidly obvious error.
Cheers
Peter
7 Replies 7
Leo Laohoo
Post the complete output to the command "sh inventory".
Thanks Leo. Here you are:
sh inventory
INFO: Please use "show license UDI" to get serial number for licensing.
NAME: "Chassis", DESCR: "Cisco C1121-8PLTEP Chassis"
PID: C1121-8PLTEP , VID: V01 , SN: FGL2517L7PZ
NAME: "Power Supply Module 0", DESCR: "External Power Supply Module"
PID: PWR-12V , VID: V01 , SN: JAB0929092D
NAME: "module 0", DESCR: "Cisco C1121-8PLTEP Built-In NIM controller"
PID: C1121-8PLTEP , VID: , SN:
NAME: "NIM subslot 0/2", DESCR: "P-LTEA-LA Module"
PID: P-LTEA-LA , VID: V03 , SN: FOC25133LM2
NAME: "Modem on Cellular0/2/0", DESCR: "Sierra Wireless EM7430"
PID: EM7430 , VID: 1.0 , SN: 355813071220716
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 port Gigabitethernet Module"
PID: C1121-2x1GE , VID: V01 , SN:
NAME: "NIM subslot 0/1", DESCR: "C1121-ES-8"
PID: C1121-ES-8 , VID: V01 , SN:
NAME: "module R0", DESCR: "Cisco C1121-8PLTEP Route Processor"
PID: C1121-8PLTEP , VID: V01 , SN: FOC24342PPD
NAME: "module F0", DESCR: "Cisco C1121-8PLTEP Forwarding Processor"
Did someone removed the PoE Daughterboard from the router?
Thanks for the reply Leo. I am really hoping it is not an optional extra that simply wasn't purchased. Certainly nobody has removed it.
I will re-investigate the BoM.
Peter
The router has a product ID of "-8P".  That means PoE.
The power supply is already the four-prong PoE-capable.
The only thing I can think of is:
  1. The PoE Daughter Board is faulty;
  2. Someone removed the PoE Daughter Board but forgot to tell anyone; or
  3. Factory forget to install the PoE Daughter Board.
Cheers
Peter
claytonsmith
We had a similar experience with our Cisco 1121s. I have had 2 Sites have issues with POE on these models. Turns out, Swapping the power brick in the back fixed it. They come with a big power brick and that usually is the culprit. When doing a show power command, It would show 0 Watts available. After the power brick swap, it would have watts available. I guess they burn out or something, or maybe we are just unlucky. Hope this helps.
-Clayton
