MAC Flapping Port and Physical interfaces
uni1389
Hi Team,
am using 2x9300 catalyst switches and i have configure two interface from server with two different VLAN 148, 14 and between two switches I have port Chanel with trunk . am getting this error on both switches , thanks in advance for your assistance.
%SW_MATM-4-MACFLAP_NOTIF: Host XXXX in vlan 14 is flapping between port Po1 and port Twe1/0/6
%SW_MATM-4-MACFLAP_NOTIF: Host YYYY in vlan 148 is flapping between port Po1 and port Twe1/0/5
spanning-tree mode rapid-pvst
spanning-tree vlan 10,14,101,148 priority 28672
interface TwentyFiveGigE1/0/5
switchport access vlan 148
switchport mode access
spanning-tree portfast
end
interface TwentyFiveGigE1/0/6
show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) LACP Twe1/0/3(P) Twe1/0/4(P)
#show run interface twentyFiveGigE 1/0/3
interface TwentyFiveGigE1/0/3
switchport trunk allowed vlan 10,14,101,148
switchport mode trunk
channel-group 1 mode active
end
interface TwentyFiveGigE1/0/4
end
interface Port-channel1
end
regards
5 Replies 5
Share the
Show interface trunk
Show spanning tree vlan 14/148
For both SW
MHM
uni1389
show interfaces trunk
Port Mode Encapsulation Status Native vlan
Po1 on 802.1q trunking 1
Port Vlans allowed on trunk
Po1 14,10,101,148
Port Vlans allowed and active in management domain
Po1 14,10,101,148
Port Vlans in spanning tree forwarding state and not pruned
Po1 14,10,101,148
show spanning-tree vlan 148
VLAN0148
Spanning tree enabled protocol rstp
Root ID Priority 28720
Address f839.18d1.a580
Cost 1000
Port 3049 (Port-channel1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 28720 (priority 28672 sys-id-ext 48)
Address f839.18e0.b380
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Twe1/0/5 Desg FWD 2000 128.5 P2p Edge
Po1 Root FWD 1000 128.3049 P2p
VLAN0014
Root ID Priority 28676
Cost 1000
Bridge ID Priority 28676 (priority 28672 sys-id-ext 4)
Aging Time 300 sec
Twe1/0/6 Desg FWD 2000 128.6 P2p Edge
Po1 Po1 10,14,101,148
VLAN0014
This bridge is the root
Aging Time 300 sec
Po1 Desg FWD 1000 128.3049 P2p
VLAN0148
Aging Time 300 sec
this your topolgy ?
I need confirm to check in which point we start troubleshooting
MHM
yes. thanks
In server the two link to SW1 config to send tag or untag frame ?
If it config to send tag frame make sure you use correct vlan ID' the server can misconfig vlan-id per link
MHM
