MACsec on Cat 3750G switches (switch to host)
Akhtar Samo
Dear All,
We are trying to enable Macsec (switch to host) on switchports but couldn't find following commands. We are running 15.0(2)se4 IPBASE image.
Switch(config-if)#macsec
Switch(config-if)#mka policy xx
Both the above commands are not available. I was able to create the MKA policy on the switch in the global configuration mode.
As per below guide MACsec is supported on IPBase images, dont know why above commands are not there.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmacsec.pdf
Akhtar
Marvin Rhoads
The guide you are citing speaks to MACsec support on the 3750-X and 3560-X.
Your older 3750-G switch does not support MACsec due to hardware limitations. Please refer to the table on page 6 of the Trustsec Platform Support matrix
We trying the same commands on 3750-x switch but its not available. Even we can't MKA policy command on it and we are running the ip base image. Any suggestions ?
Akhtar
