macsec pass-through on C9500
lastshadow
I have a requirement to pass macsec from a router across 2 C9500 to another router on the far end. i.e.
RouterA----C9500A----C9500B-----RouterB
The router supports the modification of the EAPOL destination mac address but not the EAPOL ethertype. I configured each router to use the other's mac address as the EAPOL destination mac. However, the C9500 seems to be consuming the EAPOL traffic. It's worth noting that I need macsec between the C9500A and C9500B. I turned that off for now but still no luck.
I understand that macsec is normally link-local but there are new features to make it go across provider devices such as WAN macsec and modification of ethertype/destination mac addresses to allow this. Nokia has a configuration that solves this problem, see https://infocenter.nokia.com/public/7750SR217R1A/index.jsp?topic=%2Fcom.nokia.Interface_Configuration_Guide_21.7.R1%2F802-1x_tunnelin-d10e5172.html
Is there a similar configuration on the C9500 that can allow macsec through a port or any workarounds? If not, are there any other Cisco switch models or series that would do this? My current software is 16.12.
Peter
5 Replies 5
I recomend you take a look on this doc.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-9/configuration_guide/sec/b_169_sec_9500_cg/macsec_encryption.html#concept_rhq_qbh_l2b
The way I see macsec, and implemented in a large network recently, Macsec is a Layer 2 encryption and is supposed to reside between client and switch port or between device running L2 between each other.
When it comes to Layer 3 encryption, IPSEC seems to me the reasonable choise.
Thanks for the reply Flavio. I understand how macsec works and where it is used. A layer 3 VPN is a reasonable alternative but there are other reasons why we can't use that. The routers (I had used the name router to keep things simple, but these are actually some custom switches) need to peer with each other at layer 2. I do not want the router to form macsec with the 9500. For all intents and purposes consider the C9500 switches as provider switches and the routers as customer devices where the customer wants end to end encryption with macsec over the provider network.
Peter
MACsec passthrough have been added for catalyst 9000 switches with 17.10.1 release. you can achieve the use case mentioned with 17.10.1 onwards.
with 17.10..you can. transparently forward standard ether-type 888E from the routers connected and establish MACsec between 9500 using custom ether-type(876F)..there are commands on C9k to change the ether-type.
DanielP211
Was anybody able to solve the issue?
****Kindly rate all useful posts*****
