C3560E & 'IP Routing'
zak.humphries
Can anyone please assist with an issue I am having with a c3560E
I am trying to enable layer 3 routing on this switch, but the IP routing command is unavailable e.g 'IP ?' doesn't list it. I'm using the "c3560e-universalk9-mz.122-55.SE1.bin" image and according to the Cisco Feature Navigator IP routing is available on this model. Can anyone point in the right direction for what im doing wrong???
Cheers
Zak
2 Accepted Solutions
Yes the the 3560X is a licence based model.
ie there are three licenses.
Lan-base
Ip-base
Ip-services
WS-C3560-24P-L = Lanbase (the L in the end) this is a L2 device.
This means amongst other things that it can not do ip routing due to the licensing.
If you want to do routing with the Lanbase then you need to upgrade it with a new license to minimum IP-base.
Please grab a new licence and after relaod u shld be fine
  Guy, you're using LAN BASE license.  You need to upgrade it.
License Level: lanbase
License Type: Permanent
HTH,
Toshi
15 Replies 15
Hi Zak,
    Please post the output of "show running and show ip route". Please try "no ip routing". Does this command show up in running configuration? If yes then do "ip routing" again.
HTH,
Toshi
chandu.84
You should be able to enable routing from global config mode
config t
ip routing
zak.humphries
Thanks for the replies.
IP Routing is simply not avaialble as a command (from global conf).
#ip routing
% Invalid input detected at '^' marker.
Hmmm.. I did find some information on having to licence featues, some new cisco activation thing. Looking at my licence information I think this could be the problem. My understanding from the licence FAQ is that the 3560E comes pre-licensed with ipbase?? Any ideas
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        Period left: Life time
        License State: Active, In Use
        License Priority: Medium
  You should try this:
Switch#config terminal
Switch(conf)#ip routing
HTH,
Toshi
Sorry I am doing it from global conf I just copy and pasted from the wrong screen!!
(config)#ip routing
Hi Zak,
   Please try commands as follows:
Switch(conf)#no ip routing
Does it allow you to type above command?
Please post the output of "show sdm prefer" , "show running" and "show ip route"
Toshi
Its a brand new swtich that has no config on yet..
Cheers
Zak
(config)#no ip routing
#show sdm prefer
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:                  6K
  number of IPv4 IGMP groups + multicast routes:    1K
  number of IPv4 unicast routes:                    8K
    number of directly-connected IPv4 hosts:        6K
    number of indirect IPv4 routes:                 2K
  number of IPv4 policy based routing aces:         0
  number of IPv4/MAC qos aces:                      0.5K
  number of IPv4/MAC security aces:                 1K
#show ip route
Building configuration...
Current configuration : 1582 bytes
version 12.2
no service pad
hostname XXXXX
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet1/1
switchport mode trunk
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip address x.x.x.x 255.255.248.0
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 5 15
end
  It's weird. Please post the outout of "show version" , "show license detail"  and "show privilege".
Toshi
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 06:44 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE1, RELEASE SOFTWARE (fc1)
XXXXXX uptime is 4 hours, 37 minutes
System image file is "flash:/c3560e-universalk9-mz.122-55.SE1/c3560e-universalk9-mz.122-55.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Next reload license Level: lanbase
cisco WS-C3560X-24P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1506P0YP
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : C8:9C:1D:F3:FD:80
Motherboard assembly number     : 73-12555-04
Motherboard serial number       : FDO15070BSE
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3560X-24P-L
Daughterboard assembly number   : 800-32786-01
Daughterboard serial number     : FDO150601EY
System serial number            : FDO1506P0YP
Top Assembly Part Number        : 800-31329-01
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : COMJS00ARA
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24P      12.2(55)SE1           C3560E-UNIVERSALK9-M
Configuration register is 0xF
#show license
#show privilege
Current privilege level is 15
Lan-base
Ip-base
Ip-services
Hi Chandu.84,
     Good job!!  5-Point for you.
Toshi
HTH,
Toshi
zak.humphries
grrr. .... ggrrr...
much thanks for your help
Zak
Thnx Toshi
