Port connected but not working
DANATELLLLLLLO
Hi team
There is a problem with the port, the port is connected but not working, architecture: converter => cisco => server, tried to connect directly without a switch all works, but from the switch does not ping and the mac address does not take.
then there is one think I guess it make port not work,
remove the ip flow monitor and check the port-security,
9 Replies 9
Mark Elsen
          - Verify port settings , such as correct VLAN assignment , for instance,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
show running config interface
switchport mode access
switchport port-security maximum 3
switchport port-security violation restrict
switchport port-security mac-address sticky
ip flow monitor TEST1 input
ip flow monitor TEST2 output
no cdp enable
spanning-tree portfast
Try to clear mac address sticky , but its already empty
 - For starters , go for a simple as possible port setup  , such as default int gix/x , then switchport mode host (e.g.) ; check if that can work,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
The previous configuration worked, but after a while it stopped working. I'm trying to fix it and therefore asked a question to troubleshoot
The mac is save in two table
Mac table and port secuirty mac table
Did you clear mac from both table ?
the mac address table does not contain this interface (which does not work) , it turns out it has already been cleared? I only cleared sticky
show port-security address
All interfaces have mac addresses, but the non-working interface is not on the list
