Main difference between Cisco IOS versions 12.0 & 15.0
EZRA SHYAM
Dear All,
Can some one explain main difference b/w Cisco IOS Versions 12.0 and 15.0?
Ezra..
Richard Burts
Ezra
12.0 is older and 15.0 is newer. Some new features are introduced in newer releases that are not in older releases. Most features in the older releases will be in the newer releases, though sometimes a feature will be dropped in newer releases because it is no longer useful.
Rick
Rick
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Cisco's main site has a IOS version feature comparison tool.  If you have access to it, you could compare 12.0 vs. 15.0.
