What happens if route map is invalid?
jwbensley
  • Router R1 has two fast links and one slow link
  • There is a default 0/0 route out of slow link
  • There is a route map that uses fast link 1, then fast link 2
route-map TEST permit 10
 set ip next-hop verify-availability 10.0.0.4 10 track 1
 set ip next-hop verify-availability 10.0.0.9 20 track 2
int fa0/0 ! LAN
ip policy route-map TEST
ip route 0.0.0.0 0.0.0.0 10.0.0.1 ! slow link to 10.0.0.1
If 10.0.0.4 and 10.0.0.9 are both unavailable, does the router then fall back to the the RIB which will use the slow link default route? I want to ensure that the traffic will still be routed.
Many thanks,
Richard Burts
This appears to be a duplicate post. I have already responded to the other post.
Rick
Rick
