Manage and configure an external Switch and Router
Edson Vuma
Hi guys.
Take a good look at my topology here:
I have a few questions regarding to this:
1. How I can manage those devices, the Switch and the router?
What is the BEST SOLUTION to manage this devices?
2. I want to monitor the traffic on this environment, how I can do it? How I can monitor the traffic from customer A, Customer B, and my own LAN traffic, in terms of bandwidth that has passed throught my devices? Is it possible to monitor on MY LAN, or I have to monitor from the EXTERNAL switch?
3. How I can limit the bandwidth?
I was trying to configure it using access list, with policy-map, etc....and limit this on each interface.....
Using this commands:
ip access-list extended ACL_3Mbps
permit ip any any
class-map Link_3Mbps
match access-group ACL_3Mbps
policy-map Policy_3Mbps
class Link_3Mbps
police 3000000 8000 exceed-action drop
Switch(config)# interface gigabitethernet1/0/12                           <----EXAMPLE
Switch(config-if)# service-policy input Policy_3Mbps
This configuration was going so well, but on the last command that I tried to run, it denied:
Switch(config-if)# service-policy output Policy_3Mbps                    <----It doesnt accept the "OUTPUT" word....ONLY THAT TO FINISH MY CONFIGS.
The interface does not support the specified policy configuration and/or parameter values.
Warning: Assigning a policy map to the output side of an interface not supported
With I few reading, I could see that the SWITCH 3750 doesnt support this configs.
So I searched and found this:
http://www.techrepublic.com/blog/networking/limit-bandwidth-on-a-cisco-catalyst-switch-port/404
But, now I have a concern.
My INTERNET LINK is 30 Mbps, the ports on the Switch (WS-C3750X-48P-L) are Gigabit Ethernet.
How I can limit the bandwidth here? For example, How I can limit a interface to 3Mbps
I was thinking about this:
- Limit the interface to 10Mbps: speed 10
- and limit the interface with 30% of this speed:  srr-queue bandwidth limit 30
Is this correct, is this a good practice?
Does this work for both UPLOAD and DOWNLOAD?
When the packets passes that 3Mbps limitation, will they be droped?
I hope I have clarified very well about my questions in order to have full support on this.
Any help, guys?
Edson Vuma
-- Regards Edson Vuma
28 Replies 28
Edson Vuma
Any help, guys?
Edson Vuma
Bilal Nawaz
Hi Edson, I see my example here you wont be able to use the 'output' option on the 3750's.
Using the speed 10 command wont be of use to you, this will not restrict the bandwidth. Best we can do is limit with the srr-queue bandwidth limit command.
Depends how you plan to monitor them?
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
My interfaces are Gigabit...
I have a 30 Mbps Internet LINK.
How, for example I can limit to 3Mbps?
Please
Edson Vuma
Any help?
Edson Vuma
Hey, you asked the question here about limiting before: https://supportforums.cisco.com/thread/2205845
Where abouts in your diagram are you? Is it in 'my lan' How are you intending on monitoring and managing these?
Yes, Boss Bilal.
On MY LAN.
Edson Vuma
On your Juniper FW you need to permit your LAN to 'any' for now, and if you want to lock this down to ports and protocols later you can. How are you going to be managing the devices? e.g. via ssh
How will you be monitoring devices, snmp?
Is it clear about the bandwidth limitation on the 3750?
About the bandwidth is not clear for me....
Please
using srr-queue bandwidth limit ?
Edson Vuma
Hi Edson,
You cant limit to 3mbps with the 3750. What exactly do you want to limit? If you want to limit the internet traffic out to the ISP you can do on the 1921 I think.
You also haven't confirmed how you want to manage your devices and monitor them?
Hi, Bilal
I want to manage on MY LAN.
How I can do it?
For the router, on the f0/0 I have sub-interfaces....f0/0.1, f0/0.2, f0/03
Edson Vuma
From MY LAN, can you ping the management SVI for the 3750 and the 1921? Please explain how things are set up a bit more. e.g. type of routing? the network addresses etc...
What network is customer A in?
What network is customer B in?
What network is MYLAN in?
Is the SSG doing any NAT or firewalling?
Do you need to be able to SSH to the 3750 and 1921?
You can enable SNMP on the 3750 which can give you stats but you need snmp server. If you want more granularity, you could use netflow to monitor too.
Hi, Bilal.
Sorry for the delay, had some personal probs
Here are my answers,
On the external switch, I have set 3 VLANs, and for the default VLAN, VLAN 1, I have set an IP for management.
I have a certain range of IP Addresses, so have configured 3 sub-nets on the gigabitethernet0/1 connected to the external switch..
interface GigabitEthernet0/1.10
description COMPANY_PUBLIC_LAN
encapsulation dot1Q 10
ip address
interface GigabitEthernet0/1.11
description CLIENTS_STATIC_IPs
encapsulation dot1Q 11
ip address
interface GigabitEthernet0/1.12
description CLIENTS_DYNAMIC_IPs
encapsulation dot1Q 12
ip address
I can access to the Switch being connected to any port on this switch that is on the VLAN 1, and give an IP to the PC, on the same network of the IP address of the Switch.
I cant access the router.
interface GigabitEthernet0/1.10       -    Is going to MY LAN
interface GigabitEthernet0/1.11       -    Is for a customer's LAN, with statics IPs
interface GigabitEthernet0/1.12       -    Is for a customer's LAN, with DHCP addresses.
The SSG does NAT and firewalling.
We have a 30 Mbps Internet link coming from our ISP, we have set for us a portion of this and for our customers too.
But I would like to monitor the traffic that is being generated.
Where is the best part to monitor all this?
On “MY LAN” or on the EXTERNAL ENVIRONMENT?
Edson Vuma
Hi Edson, I'm working on a lab for this and will share configs with you a little later. What is the default gateway for the CUSTOMER A and CUSTOMER B? Is it the firewall or the 1921?
Hello Edson, I have replicated the topology with the exception of the firewall since the SSG is more advanced. I am able to ping everywhere which is the main thing. Everything terminates on the firewall, so your cust1 and cust2 have to go through the firewall for security reasons.
With reachability everywhere it means you are able to set policies on your FW to allow things like SNMP and SSH to your switch and router. The config of the 1900, 3750 and the FW are below, I will also attach this PT in the case that you are able to download and open in packet tracer - if you have it.
1900:
hostname 1900
spanning-tree mode pvst
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 1.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 1.0.0.1 0.0.0.0 area 0
default-information originate
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
access-list 1 permit any
3750:
hostname 3750
description 1900
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 5
interface FastEthernet0/4
switchport access vlan 6
FW:
hostname FW
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 1.0.0.254 255.255.255.0
ip nat outside
interface FastEthernet0/0.5
encapsulation dot1Q 5
ip address 5.5.5.1 255.255.255.0
ip nat inside
interface FastEthernet0/0.6
encapsulation dot1Q 6
ip address 6.6.6.1 255.255.255.0
ip nat inside
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
network 1.0.0.254 0.0.0.0 area 0
ip nat inside source list 1 interface FastEthernet0/0.1 overload
With this configuration, I am able to reach everywhere, so you will be able to use management and monitoring tools and protocols like SNMP, SSH, Telnet, Netflow, but i have not included the configuration in this, since the config will have to be done on the FW policies to allow this traffic.
Hope this helps.
