Management interface and log server
donohoecompanies
Frequent Visitor
Frequent Visitor
On our switches we have a production network (172.16.4.0/22) (VLAN4) that servers and clients sit on, then we have a management network (172.16.8.0/22) (VLAN10) which the management interfaces of various systems sit on, including our switches. We want to send logs from our switches to a data collector which sits on the production network, but only allow management of the switch from the management network.
Would this configuration achieve that, and is there a better way to do it?
interface Vlan4
ip address 172.16.4.40 255.255.252.0
interface Vlan10
ip address 172.16.8.40 255.255.252.0
ip access-list standard Management-SSH
permit 172.16.8.0 0.0.0.255
logging trap debugging
logging host 172.16.4.19
line con 0
line vty 0 4
access-class Management-SSH in
line vty 5 15
transport input all
balaji.bandi
As long as routing in place to reach management network and data network Logs will reach destination.
you can also use Logging using the interface.
Logging source-interface x/x
or you would like to make ACL to allow only syslog messages to allow ?
is this make sense ? what challenges you see here ?
BB
